Can nothing every just work
Anyway. I'm setting up the wireless ethernet converter Buffalo WLI-TX4-G54HP. Setup is explained well and almost there but now this.
Logged into the configuration software through the web, I search for my network, I select my network. Then I need to enter my key for WEP64. I enter in the 10 numbers, hit apply, and I get this:
Error: AirStation detected an error with an input value.
Item: Wireless -- Character input for encryption key (WEP)
Detail: 1 section : The length should be 5(64bit encryption)/13(128bit encryption) characters.
Does this device only use characters and not digits for WEP keys? As my D-link router only says to use 5 for ASCII text characters, but 10 for hex digits. I have it set with the 10 digits. The input on this g54 for the key said nothing about it needing to be ASCII except for maybe the blurb above that says characters, no option for HEX. You'd think they'd mention that somewhere in the setup guide or in the config.
I guess I'll reset the key to ASCII with 5 text characters and see if it finally works.
