G34 Water Cooling
NickOfTime
[H]ard|DCer of the Month - April 2014
I have an kgpe-d16 with dual amd 6234 processors in a Antec P280 case, However I had use
Dynatron A8 1U coolers which are really noisy. Currently running 56C at 100% load.
Can I remove the Fan from the A8 and mount a Liquid Cooler to the A8 Block or is the only option is to use the Koolance G34 water Blocks?
Easyist Local Supplier for me is http://www.memoryexpress.com/Search/Products?Search=liquid+cpu+cooler
