Shrimpanzee
- Nov 30, 2008
I'm replacing my Gateway FPD2185W that I bought in 2006 in search of a better display for non-gaming computer use and Xbox 360 gaming.
I don't care about 16:9, as the G2400WD supports 1:1 pixel mapping anyways.
So, does the E2200HD have any technical advantage such as input lag over the G2400WD....or are they pretty much the same panel with a different native resolution?
Input lag is my top priority because I will mainly be playing FPS games.
