G15 volume control doesnt work...
Hey guys, for my new build I got the logitech G15, but one of the things I loved most about my previous keyboard(logitech elite) was the volume wheel. The G15 has one, but it doesnt work for me.:( With my previous keyboard, whenever I turned up the volume or down, it would show up on screen in green, just like when I turn on/off caps lock, etc. Well turning on/off caps lock etc with the G15 still works and shows up, but no volume control. I've installed it 3 different times to no avail. Has anyone else had this problem and know of a solution?
Sorry, man. I haven't experienced that problem. It has worked fine for me since I first installed it. A friend of mine has one too and I'm pretty sure his works fine as well, but I'll ask and see if he knows anything about it. Good luck.
Did you install the software for it before you plugged in the keyboard, and then did it ask you to plug in the keyboard? Thats what the instruction manual said to do and I did it, but it never asked me to plug it in to finish, just finished without it.
Yeah, I installed the software first and I don't think it ever asked me to plug in the keyboard. As I recall, I just plugged it in, and it all worked. My buddy said that his works fine as well, and doesn't know anything else to be able to help you out on the volume control issue. I've never had to contact Logitech tech support before, so I don't know if they're any good, but you might give that a shot.
Best of luck to ya. :cool:
We have a few G15's and none of them have any problems with volume.
*sigh*
I guess I'll try uninstalling the software then unplugging it and plug it back in without installing the software.
Yay it works now! I have no clue how but it works! lol. I did what I said in the previous post and that didnt work, so I went ahead and reinstalled the software with the keyboard unplugged, then when it finished I plugged it back in and it worked. Yay for me! Thanks anyway guys.
Glad it worked out. Also, keep in mind that in some programs (For me atleast) the volume control will not respond. Such programs include SmartFTP and virtually every other FTP program I have tried. All the same thing.
So next time you go to upload something and try to turn up/down volume and nothing happens, don't be alarmed just minimize the upload window and it will work.
