G11 turns off then on?
Zake202
I've had my new logitech G11 keyboard for 4 days now.
So far I have noticed this problem twice at random.
What basically happens is I'm playing WOW, and all of the sudden the LEDs turn off and I can't move, then come back on and I can. It's a total of about 5 seconds when this happens.
I mainly suspect the USB not drawing enough power, but I'm not sure.
The second time it happened was today, and as far as USb devices I have 4 plugged in total.
My Webcam, Printer, Keyboard and mouse.
I also had the drivers off the CD installed until about 20 minutes ago (after the problem)
I updated them from 1.0.3 to 3.0.1, not sure if that could be the reason why it was turning off or not.
Any ideas?
Nope, probably a hardware issue IMHO. I had/have a Logitech G15 keyboard and this "feature" was driving me insane. I also had my mouse plugged into my board, so when this happened, I lost all control. I can't count the number of times I've died in Lord of the Rings online (caused me to wipe a whole raid by auto running into the boss... not cool).
I tried multiple USB ports, tried without the mouse plugged in etc. still had it happen.
I also tried using this board on another machine and also got the random disconnect while just doing some windows stuff. I don't know if this is a widespread issue but I have seen it posted about on some online forums when I was looking at it. Most people just said to send it back to Logitech for warranty. Unfortunately my board was a couple years old, so I haven't bothered.
I bought the Deck 82 keyboard and I have not had this issue at all. Awesome keyboard BTW and it cost me ~ the same price I payed for the G15, I'm a happy camper now. :)
You had the same issue though?
The keyboard leds would shut off and you couldn't move in WOW or use any of the keys and then the LED would come back on and it would take a few seconds for the keys to work again?
Like it power cycled basically?
I don't have another USB keyboard to actually test, but there has been no issues with my microphone printer or mouse.
I do have the keyboard plugged into my old PC that my GF is using hoping to see if it happens on that.
That is a good test to see but yes, I had exactly the same problem with my board. It would basically disconnect from the PC as if I unplugged it, sit there like a paper weight for a few seconds, then re-connect, LEDs would turn back on and then shortly after the keys would start to respond. It was a royal pain in the arse.
Sounds like the same issue then.
She used the keyboard for an hour last night with no issue.
Then again, the issue only happened to me 3 times in 5 days. So I plan to leave it plugged into that PC today and tomorrow and possibly go buy a second G11 to test with.
What do you suspect the cause of it being? In your case it seemed to be the keyboard itself, in mine I'm not so sure yet.
How often did it happen to you?
I couldn't put an exact figure on it, it was pretty random, but at least 5-6 times a week if I was to take a guess.
Ok thanks.
Hoping it doesn't happen to this new keyboard and if it does then I know it's something with my PC.
Anyone else have any ideas?
Had this new one for 3 days but have only used it 2-3hours a night.
Not the length I was using it over the weekend which was 6-7hours.
No issues on either yet.
Still have a feeling something is wrong with my PC but not sure what it would be.
There is no power loss to my USB ports, I've tried all of them.
The keyboard never said it was disconnected when the issue happened, just turned off then on.
