Agreed. Price and compatibility with the motherboard would be the determining factor for me if it was a choice between the two companies.I like both brands. Both are solid companies with solid products.
Both are great companies.
However, I found out recently that my 6gb kit of Corsair RAM wont run at rated speeds (Its DDR3-1600 @ 8-8-8-24-1T 1.65v)
This was kind of disappointed as they are "guaranteed" to run at the rated speed and supposedly tested before they leave the factory. I guess thats a load of crap right...
Though, I cant be mad at Corsair though. They make some quality products. I have the 800d Obsidian case and HX1000 psu. I love them both.
That being said, GSkill has treated me well over the years too. I had some GSkill HZ DDR2-800 ram that ran beautifully.
looks like dual channel only
why do you want them?
http://www.newegg.com/Product/Produ...=50008476&Description=eco series&name=G.SKILL
Uh, RMA it. Mine run higher than rated if I wanted it to (1600 C7s, goes to ~1800 C7s without issue).
