G.Skill snipers
it really depends on what programs you are testing the difference between
games, little difference. even less of a difference if you stay at 1600mhz and only tighten the timings.
i think WinRAR might benefit a bit from higher speed
i suppose bottom line is... you have 1600mhz sniper modules, you should just make sure they're running at (or above, if you can without pumping voltage) 1600mhz and at specified latencies.
your bios is probably pretty smart and have already put you at those settings, just take a look at CPU-Z to confirm the settings and check with them in the BIOS
