G.Skill Overclocking
ahmadmz
Im having problem with overclocking these.. the max i can go is +5Mhz and thats also with just ~30 mins of memtest.. anything higher won't work at all.. I have the Black 2GB DDR500 sticks. I havent touched the timings and i was trying to find the max but they simply wont go any higher than 255! is there anything i can do about this ?
Try loostening up a bit, and giving it a bit more juice.
i think those sticks dont like juice. Whats the first 3 digits on the serial. I know some on xtremesystems with 604s that wouldnt go over 258 so that sounds about right.
This is usually where voltage and secondary settings mess you up. How about you post a shot of A64Tweaker's DRAM settings? :)
I'm using the default timings, 2-4-4-8 and my system is Opteron 165 currently @ 2.2GHz but when i was OCing the ram it was at stock 1.8GHz. I tried adding a little voltage but that didnt help at all, so yeah.. voltage won't help im sure.
you lowered the cpu multi to overclock the ram?
you still haven't told us the rig, other than the cpu from those timings.. i'm gonna guess a dfi of some sort.
a few things:
1. try an odd drive strength.. like level 7
2. airflow and more airflow over the ram!
3. raise trc to ~9? and trrd to 3
Oh sorry, this is what i have..
DFI LP Ultra-D
G.Skill Extreme Series 2x1GB DDR500
Enermax Liberty 500W
AMD Opteron 165
I did try to lower the multi but still no good. I just ordered a new HSF + fans for my pc to make it cool. I should get those by 3 days.. then i'll try what u suggested and reply here. Thanks.
ah a dfi. well, for now, take a look at the two links in my sig, they're kinda written around the dfi bios :D
Hmm, can it be that i am not able to overclock due to my bios? I have no idea about that.. i'll try to check which bios i have and which is best.. maybe that would help?
no matter what bios you have, the dfi is made to be overclocked... ;)
did you read and understand the guides in eclipse's sig? :D
