fx5700 or 9600 aiw
mpegripper
which card is better
i'm specfically looking at the gainward 980(which is the fx5700 pro with dual dvi and 256mb), wince it has vivo and i need that
and the BBA 9600 pro aiw
any others to look at for the price'
i need vivo
TIA
VIVO on the Gainward is probably only S-video or composite, so if you want to watch TV on your computer or plug in a coaxial cable, you'll have to get a seperate device to convert the signal. The AIW has this hardware onboard. As far as gaming performace, others may know better than I...
i have a satelittle so i use the s video from that
my ti4600 just died and i know that setup works for me
anyone know about the heatpipe fx5700 from gainward, does it run a lot hotter?
Depends on what your priorities are...the FX5700 is going to be a little faster for games but the 9600 AIW is going to have more features. Are you a heavy gamer? if so you would be better off with a 9600xt/ modded 9800se/FX5900. If not then the 9600 AIW should meet your needs for a while.
(the above post assumes you are on a budget so that's why I listed the cards I did)
i think i'm gonna get the gainward
anyone have experiences with the heatpipe version?
