FX53 Overclocking Help Needed
PSYKOMANTIS
I'm a vetran of using Intel systems for overclocking.
Using unlocked multipliers is a super new thing to me.
I've searched the forums and for the life of me, I can't find anything on 53s.
My setup:
Asus A8V Mobo
Kingston HyperX PC3500 CL 2.5
AMD Athalon 64 FX-53 Socket 939
MSI 6800GT
Enermax 475W
I'm curious what is the exact protocol or procedures for squeezing a bit more juice out of that 53.
To what I am seeing you drop the multiplier, raise the FSB, and increase voltage.
If any of you have any specs of your FX53 systems and your experiences with your processor would greatly be apprecieated.
Thanks for any information the [H] can provide.
Psyko M.
you pretty much guessed it all right there. Just make sure you have the memory timings set if you want more out of your memory. I haven't used an fx53, but they're pretty much all the same. almost.
