Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I know its an old card, but im helping out a freind on a budget.
Does the NVIDA 128MB Geforce FX5200 support dual screen spanning or is this model cloning only? It has vga and dvi but im unsure how far back support goes.
Off the top of my head, any GF4 or higher automatically supports spanning- especially with multiple connectors onboard. Each card can support up to two displays, after which it will start cloning (TV will clone one of the monitors, for example). You can also span across multiple cards.
