The gig ud3 is very different then the ud5/7. It's not just the cooling. It has the same older vrm and power delivery that the 7 and 8 series boards had. It's a great board for phii, but it can't even handle an fx-8120 at stock if you disable the throttling. They don't have an option for it in the bios because it can't handle it. I did a work around to do it, and it killed both the board and CPU. Again at stock speeds, using prime95. Vrms and nb were pushing well past 100c.
__________________
Negative sir, the revision 1.0 boards were that way. The 1.1+ revisions all offer LLC, which is exclusive to digital Circuits.
I have the ud3, revision 1. and your findings are COMPLETELY FALSE. My VRMS do not go over 60c. (i did add a fan to that region) The throttling was a bios problem, and has been fixed, but if you disabled cool and quiet before it was fixed, throttling was only a issue with cool and quiet enabled. I can clock my 8120 to 5.2ghz on the UD3 revision 1.0. No throttling or anything nasty like that. Maybe you should have tried to update your bios.....
The UD3 is a great board for the FX processors, and soon to come FX piledrivers.
