Posting this in the AMD processors section and not the general Overclocking section to avoid Intel cranks.
Currently have the top OC for the FX-8300 on hwbot.org, H100i on CPU as noted in the comments. I got into Windows at this speed and it would POST at 5.0GHz but BSOD before I could get into Windows. I'm going to keep tweaking it and I hope to get over the 50% OC hump. All things considered, it isn't IBT/Prime stable at speeds like this (so far anyway), I end up taking it back down to 4.2GHz for daily use and gaming and I'm still working on some stability issues at that speed (ARMA2, I'm looking at you). I was going to hold out for a deal on an 8320E but went for the 8300 instead (pre-Xmas deal kept it under $100 from TD), and I'm glad I did.
