FX-8120 $150 @ MicroCenter
Gawdamighty! Why can't I have a Microcenter near me? Closest one is 2.5 hours away in Atlanta so with sales tax and gas, I'm right back at $180-190. Still, might be a good excuse for a road trip......hmmm....
Combo deal with mobo too, and if you can find an open box Sabertooth and get the combo deal, you are golden.
EDIT: Ah, I see you have one already.
LOL! Yes, my all time favorite motherboard. That part of the reason I want one. This board is such a great overclocker and seems to be bulletproof, I want to see what I can do with a FX. I know I wont really be picking up any additional performance over my X6 but I could have some fun cause Im kinda bored with my year and a half old Thuban.
Ive done a lot of testing, and while the thuban is faster at stock or clock for clock, when you compare max OC to max OC its different. Max OC for a Thuban is 4-4.1 (with a normal good air cooler or AIO water cooler) while for the 8120 its 4.6-4.7. Plus you can run the ram a lot faster with the 8120. At best daily settings, the thuban is only slightly faster in single threaded, but the 8120 is much better in multitasking and in multithreaded apps.
I have mine at 4.8 and can convert a full FLAC album (12-15 ~4min songs) to highest quality MP3s in about 20 seconds. The other day I was downloading a few things, had music being converted, about a dozen tabs open in FF, listening to music, had a bunch of monitoring stuff going, and the whole time the CPU usage stayed low and temps never went over 42C from 35C idle.
Not bad at all! I pretty much only use my rig for gaming and internet so and my X6 is doing a good enough job that my 5870 is matching all the benchmarks Ive seen on review sites so I take that as its doing just fine. I know that the FX line is a tad slower in games at least at stock clocks but Im wanting to see what happens when you open one up a little. Especially the NB. Phenom II's really wake up with you crank up their NB's to 2600 MHz or better. Im really curious to see what that does to a Bulldozer.
LOL! Yeah i got the 8120 today and an OB Sabertooth for $69 after the discounts and talking the manger down because it was missing the I/O shield. Really wanted another 960t, but this is just a sweet deal i couldn't pass it up.
Agreed. I want to pull my hair out... Need to petition Microcenter to come to my area...
Bought the 8120 + Sabertooth combo last week when cpu was 179.00
Still working on it. I optimized voltage at 4530Mhz 259x17.5 with 1.3Vcore stock everything else, with NB and HT at x10 2590Mhz and 4x4GB ram at 2070Mhz 9-9-9-27 1.575V when I had an H100. Just put in a real water kit and haven't optimized everything yet, but so far am at 4766Mhz 251x19 with 1.375Vcore and stock everything else, with NB and HT at x10 2500Mhz and ram down to 2000Mhz. Still trying to find the sweet spot. Using 62C as my temp limit, and haven't gotten there yet with the real water setup.
Guess it has to be a "real" water kit to get much of anything over 4.6 stable from what Im hearing. Temps seem to go thru the roof over 4.6 and itll take something pretty hefty to keep them cool above that. I think I remember Kyle saying that the H100 they used while overclocking the FX-8150 was barely cutting it and thats saying a lot cause thats a pretty solid cooler. If I do pick one up, I guess I should upgrade my cooler as well. My Hyper is going a great job with this Thuban but think it might be overmatched with a FX.
When I had the H100 on it, I got 4650Mhz stable with max load temp of 62C with two fans at 1k RPM. Real water seems to only gain 150-250Mhz over good air/AIO water like with most stuff. With the 2500K I went from an H60 to real water and only gained 100Mhz in CPU speed (from 4.8 to 4.9).
That sounds a little high. Isnt 61 the max safe temp for these things? I wouldve thought a H100 could get into the 50's at least.
64C is where most boards throttle half the cores down (the Sabertooth has settings to disable this) and 62C is the recommended safe temp for stress testing. In daily situations you will never come close to your max stress test temp.
H100 is in the 50C or less at stock or with a slight OC. When you push it though, it heats up.
Also, sent you a PM.
If anyone doesnt have a MC near them, Ill likely be there tomorrow to get a mobo, and can pick one up and send it. Likely end up costing you $170 shipped.
This seems "hot", but if you consider the 2500K costs $179, it's not so hot...
Am I the only one?
Am I the only one?
It is if you have an existing AM3+ platform and looking for an upgrade.
Am I the only one?
The 8120 is a better multi-threaded and multi-taksing CPU then the 2500K, and AM3+ offers things 1155 does not (6x SATA3 ports, 16x16 PCIe lanes, better ram clocking, more compatibility, etc..)
Plus the OCer in me is bored with the 2500K. All you do is up the vcore and increase the multi and your done. The 8120 has a lot more toying.
Its not showing the mobo discount on the sabertooth in my cart, do I have to talk them down in store when I pick it up to get that to work?
Sometimes the online cart doesnt do the combo when it should.
I just got one of these last night at Microcenter to play around with. I also have a 1045T from a previous Microcenter trip, and I went cheap previously with the cheap Asus 760G board, but it supports an 8120 so I dropped this 8120 into that same board. It runs fine but makes me nervous since it's just 3+1 and there are no heatsinks in the VRM area.
Anyway, I read somewhere that speeding up the NB on bulldozer doesn't really help much in performance like it does with Thuban. I'm not much of a gamer so my testing consists of running a part rebuild benchmark in SolidWorks from here
This is mostly a single threaded type benchmark. Yes, SolidWorks is multithreaded, but part rebuilds must go one feature at a time and really only stress two cores most of the time.
At stock settings, the 1045T takes 92 seconds.
I run DDR3 1600, so for overclocking I change the reference clock to 240, then I set the NB at 2400, HT link at 1920, drop the memory multiplier to the 1333 multiplier, change memory timings to what they should be, and that is about it. Stock voltages. That gives me 3.24 Ghz, and I leave Turbo enabled because it does help with this single threaded solidworks test. The overclocked result is that the time drops to 79 seconds. Nice improvement there.
For the 8120, all stock, it took the same 79 seconds. I just changed the NB speed to 2600 and the result dropped to about 78 or so. I am rounding a bit here too, so in other words it made no real difference. With this cheap board I have not had the guts to try any overclock yet.
I also had a 960T and did the same test. At stock it was also around 92 from what I remember. Upping the NB from 2000 to 2400 with no other changes made the time drop to around 86. Of course we all know upping the NB on a Thuban really helps performance, but I don't see the same thing with my quick and short test on the 8120. Of course these are very limited results and gaming may show something different.
The 8120 does not use much power at idle, that's for sure. I was using the built in video on the Asus board and my Kill A Watt was showing about about 70 watts at idle in Vista.
This is with an old non 80+ power supply too. To be honest it is a 400W sparkle I got at a local Goodwill of all places.
If I hadn't of jumped on a 960T when they went to 100, I would go get one to mess around with. already have an x4 830 sitting around collecting dust...I really need to make a for sale thread... I just can't see this being that big of an upgrade over an unlocked 960T at 3.8+ghz in gaming. Anyone have figures?
Priced right.
If IB S1155 turns out to be a flop I might jump on a deal like this and build an AMD build. My 2500K works great but I already know my system limits and I really just want to try something new in this price range to have fun with.
Hoping IB 3570K can offer a nice affordable upgrade from 2500k for this summer to have fun.
