FX8350 is at $179
And the
FX8320 is at $149
Locally here though u have to pay tax so add about 8-9%
But 8320 or 8350 seem to be both better than the 6350... I opted for the 6300 due to budget.
Hope u are happy with the 8320 =) let us know how well it works.
I opted for the 6350 as well so I didn't have to skimp elsewhere, also I heard the "news" that steamroller will be am3+ so I decided that a 6350@5ghz is just damn fine until I buy steamroller.
Recent news I heard Steamroller will be on a new socket.
you did not even read the thread. you must need to get to 50 posts to sell something as you popping them off every minute. lolwhy not a 8320?
um the 6350 has the same TDP as the 8320. both the 6350 or 8320 will need to be oced anyway to get best use out of them if using more than a mid range gpu.I myself thought of getting an 8320 but the more I think about it 6350 is more practical. Not because it's cheaper but because it is only 95w or so and should run a lot less hotter. Most games only use 4 cores anyway.
Doesn't matter. AMD is about geek porn, and 8-core geek porn beats 6-core geek porn.I myself thought of getting an 8320 but the more I think about it 6350 is more practical.
Just because Kaveri will be the first steamroller cores to hit mainstream desktop on FM2 doesn't mean steamroller on AM3+ won't happen. I'm not sure what socket Berlin is going to use either. FM2 as well or a new socket?
The 8350 is a higher binned chip and will likely give you slightly better overclocks or be more stable so that like my 8150, you can run a pretty high overclock while also being able to use Cool N Quiet which is awfully nice. The 8350 can routinely be found for $20-30 more than the 8320 and might be worth it to somebody looking to wring every bit of performance you can out of a chip.
Sorry to threadjack, about two weeks ago I asked nearly this same question, I read through the thread, did a little soul searching, and snatched up the 6300 for $104. Started overclocking a couple days ago and got to 4.8ghz @1.5v stable, hit the wall and cannot seem to get any higher. So far I'm pretty happy, I would like to hit 5ghz but would have to crank the voltage up higher and I don't think my old Zalman 9500 is up to the task, temps are okay 28c idle and 55-65c under load but I have pretty stellar airflow going through my case.
What's wrong with your 8120? Definitely wayyyy faster than the x2 550BE I just upgraded from lol!If you'll keep posting numbers like this I'm going to end up with a FX-8350 on my doorstep.
To be honest I would rather save the $20-30 and get the 8320. Chances are they will oc to the same level. I remember back when I built a amd comp with a 955be while my cousin paid the extra $ for a 965 for his. Was able to clock mine at 4.0ghz while he was stuck at 3.9ghz. Just comes out to be luck of the draw on the kind of chip you receive.
