Sniper_Merc
- Mar 25, 2004
Just wondering cause I have a friend with one that seems to be running quite hot, and i think theres a posiblity that the thermal compound between the heat spreader and the core has come loose. Temps are hovering in the 85-86 C range and thats after replacing the stock cooler with a VF 700.
Thinking that just a razor blade around the edge will allow it to be popped off.
