FX-57 and 8800GTX
I think the FX-57 is plenty for the 8800GTX. If you want to gain the most out of your setup, I suggest overclocking.
It'll be fine. Synthetic benchmarks will be hit fairly hard, but in game performance won't differ too much.
The FX-57 is still a pretty fast chip. It shouldn't bottleneck the 8800 much.
yeah, your fine.
what your gonna wanna do is kill all background applications, close anything that takes any cpu resources. close all apps that you can,. you can ever get rid of explorer, just go to applications and "end task". when your done your game, go new task and just type in "explorer".
Sure it will work (great), but a better CPU will show a measurable improvement.
Well with Core 2 Duo CPU Your E-pennis will be much longer. :)
My GTS works great with my alredy so "old" 4200+ on 20" wide screen.
Though next chance I have and C2D here I come :)
Do I need it? No. Though I want it :)
MD
I always have to enter these threads and say, "yes" there was a noticeable difference. I had my athlon64 at 2.6ghz and it bottlenecked the hell out of my 7900GT. My games have come alive since I switched to the C2D.
