FW900 Resolutions
rabidz7
These are some supported resolutions for the FW900. I have not tested them myself, as I do not own a FW900 (yet :D), but they are based on the HScan and VScan range, so they should work.
FW900 Specs:
HScan range - 30KHz-121KHz
VScan range - 48Hz-160Hz
Dot pitch - 230µm
Supported Resolutions:
....Hz............Res..........Pitch
160Hz - 1152x720 - 448µm
144Hz - 1280x800 - 404µm
128Hz - 1440x900 - 360µm
120Hz - 1536x960 - 336µm
115Hz - 1600x1000 - 323µm
110Hz - 1680x1050 - 307µm
105Hz - 1760x1100 - 293µm
100Hz - 1840x1150 - 280µm
96Hz - 1920x1200 - 269µm
90Hz - 2048x1280 - 252µm
85Hz - 2176x1360 - 238µm
80Hz - 2304x1440 - 224µm
72Hz - 2560x1600 - 202µm
64Hz - 2880x1800 - 180µm
60Hz 3072x1920 - 150µm
57Hz 3200x2000 - 162µm
55Hz - 3360x2100 - 154µm
52Hz 3520x2200 - 177µm
50Hz 3680x2300 - 141µm
48Hz - 3840x2400 - 135µm
Anything above 1920x1200 quickly goes from uncomfortable to unusable, in my opinion.
There is a 9 year old thread for the FW900 on [H].
What gave you the idea that this post was worthy of it's own thread?
