Future water cooling build, some quick questions.
Dolph
Hey guys,
Im going to be doing an end of summer project water cooling build, id like to start planning for mods to my case/what not.
Im going to be cooling at least: i5 2500k (currently at 4.7ghz with an H60(pull)) : most likely IB later
2 x GTX680's or possibly a 7990. Now with those components in mind, would a single 360 radiator in push/pull configuration be enough heat dissipation? Or would i need an additional 120/240 rad?
It is worth noting that i have the haf x case, so i can comfortably fit a 360 radiator in the roof, but i really only have room for another 120 either in the rear or front hdd's are, without modding ofcourse.
If i require more than a 360 + 120 radiator, i will have to either add 2 x 120's or mod the bottom hdd's cage out, as well as cut the bottom part of 5.25 bays to fit in a 240. I have a bunch of scythe kaze ultra's coming in soon with a 5 x 60w/channel fan controller, as well as one delta fan (for my current, inadequate h60 w/ stock corsair fan)
I appologize for the noobish questions, ive never experimented with a custom loop before, also, i realise i didn't provide any additional information as i am open to many schools of thought for parts/ideas/cases. Please give me any feedback you can.
What RPM do you plan on running those UKs at? Or rather, what RPM/loudness are you comfortable with 24/7? That will determine if a 360 is sufficient, but most likely it will be.
i think martins labs calculated the ultra kaze going through a rad @1500 rpm was somewhere around 44 cfm, and at the full 3000 was somewhere like 84 - 85
edit: Sorry for double post, very tired.
I have an X79 setup with a 3930K at 4.5 and two 7970.
I use Heatkiller blocks.
I have an MCP 655 and two radiators.....120.3 and 120.2.
Temps under gaming use show about 45C on the CPU and 45C on the GPUs.
Keep in mind that the CPU will hit 70C fully loaded on air and the GPUs are generally 65-67C at 65% fan on the stock cooler.
Hmm, the more im looking at it, my components are going to be massively overclocked, im thinking that i might need the additional 120.2... With 2 video cards, however, apparently the new kepler cards are relatively low in power, less heat.
Typical rule of thumb is one fan per cpu/gpu. So you'll have three total so you'll need AT LEAST a 120.3 or 140.3. Also, different rads have very different performance characteristics. A Black Ice 360GTS vs 360GTX are going to perform much differently because the GTX is a significantly larger radiator with a lot more fin area. The other significant variable is how much air you're blowing through those fins. The higher the RPM, the more heat is dissipated and there are significant differences between 1200 and 1800 RPMs. Definitely recommend higher RPMs, which means you'll likely want the Scythe AP-15 fans.
Personally, I would recommend a dual-radiator approach if you're planning on overclocking as much as it sounds like you will. Overclocking generates quite a bit of heat and a single 360 would be pushing the limits. Make sure you get a strong pump as you will have a lot of components you're pushing water through (3 water blocks, possibly 2 rads, a reservoir, etc)
Actually, the GTS and the GTX perform similarly. The GTX may be thicker, but it has a lower FPI than the GTS. The GTX will always outperform the GTS, but marginally in push/pull with fan speeds above 1500 RPM. The biggest differences between radiators you would find would be between the Black Ice GTX and XSPC RX radiators. RX radiators stomp all over the GTX and GTS radiators at fan speeds below 1500 RPM with only one set of fans, while GTX and GTS radiators stomp all over the RX radiators at speeds above 1500 RPM and in push/pull.
Tsumi is the smartest person I know on this forum when it comes to watercooling. Helped me get my rig together conceptually (for which I am thankful!). Best rad will definitely depend on fan-speed as was said.
I appreciate your input!
I currently have 4 x Scythe Ultra Kaze 3000rpm, usually undervolted to 1500 rpm~ for my H60, if im goignm to game ill crank them up, since i rarely play with no sound.
for the pump i was going to consider the
Swiftech MCP655, ive heard it was a powerful and reliable pump
Tsumi, i will keep your name down somewhere for future reference, i know i have a great deal to learn. Thank you as well Minister.
Is this the radiator that you were refering too?
http://www.frozencpu.com/products/8523/ex-rad-146/XSPC_RX360_Triple_120mm_Radiator_Rev_2.html?tl=g30c95s161
I see that frozencpu has its RX 120.2 counterpart.
A side note: Does anyone know how frozencpu is for shipping to canada? Fairly pain-free i hope, ncix doesn't sell too many specific items for watercooling.
I ordered my first gtx 680 today as well :), MSI Version.
Thanks, but I get most of my info from Skinnee labs and Martin Liquid labs.
With a HAF X, I would get a single 360 radiator. With only a 680 and a 2500k, you probably would never need to crank those fans above 1500 RPM. With two 680s, you might feel the need to turn them up to 2000+ RPM.
I would get the Black Ice GTX 360 radiator with those Ultra Kazes. If you want a cheaper radiator or a thinner one, you can get the Black Ice GTS 360 radiator.
A single 655 is definitely more than sufficient.
Thank you! I will go for at least the GTX black ice 360 then. If needed, would a single 120 make any difference at the point of a second gpu in the loop?
The pump and radiator is solved, for now at least, would you suggest the XSPC Raystorm Water block? Are there many specific differences in performance for waterblocks? Also, i was reading that 90 degree fittings take a toll on the pump, with 1-2 90 degree fittings be negligible with the mcp655?
The Reservoir is a pretty moot question isn't it? Get which ever one suits my needs for the case layout, and make sure it comes before/above the pump in the loop?
There was testing done on the 90 degree fittings, and testing showed that you would need about 30 of them to equal the resistance of one CPU or GPU block. So, don't worry about it. You can use as many as you want.
I doubt it will make a difference with the fans you're running. Usually, the point of adding more radiators is to run the fans at lower speeds for the same cooling performance.
I would suggest the XSPC Raystorm or the Swiftech Apogee HD. Both are the top contenders at the moment. Blocks do differ in how quickly they can transport heat from the CPU to the water, and how restrictive they are in the loop. Both the Raystorm and the Apogee HD are some of the least restrictive blocks ever made, and both have top-notch heat transfer. You can head on over to Martins Liquid Labs for more details on the testing. He was also the one that did the testing on 90 degree fittings.
Indeed the reservoir is a moot point. Make sure it suits the layout, and that it suits your aesthetic needs at the price you want to pay. 99% of reservoir choice is about aesthetics and cost, as long as they're good quality, which most are.
This has been very helpful, thank you very much! If you tsumi or anyone else has any comments or input please please drop them in.
