hey, im going to build a comp in about a month to a month and a half (as soon as i can get my hands on a x1800xt), and i wanted to run my specs by everyone to make sure im not making any horrendous mistakes or nething like that
x-qpack black windowless
tforce 6150/430 mobo (there'll probably be a lot more of these to choose from by the time i get around to building, i'll choose whichevers best)
ati radeon x1800xt (dont argue, employee discount = 50%)
opteron 144 s939 processor
preferrably 2x1gb of some cheap ram if i can find a good deal on them
hard drive i already have
whichever dvd burner is cheapest at the time i buy with a black bezel
i think thats everything. what heatsink would be recommended? zalman 7000? 7700 is bigger and should cool better, right? does it fit? and is the xp-90 significantly better than the zalmans?
also, i need a psu recommendation, too. not something too expensive, though, im trying to kinda keep costs down. im currently looking at the xclio 450W, do you think that would be enough? i might want to change, though, for something w/ active pfc along w/ dual 12v rails instead of no pfc dual 12v like the xclio is. i might just end up stretching the budget and getting a neoHE 550, but if possible i'd like to keep the cost down a bit.
