"future proofing" a new Intel build, need strategy ideas
Juardis
My current rig is a P3-1 GHz, 384 MB DDR RAM, nVidia Ti-4200, IBM 10K RPM SCSI HDD and 1 cd-rom, 1 cd-rw. In other words, I built it, upgraded it as much as I could over the years, then nursed this thing for as long as I could. It's lasted 9 years from when I first built it. But now it's time to retire it and start anew.
I know I can't "future proof" anything, but I would like to have a logical upgrade path for the forseeable future. That's where I need help. The goals are to only have to replace 1 component at a time when upgrading, and to stay within shouting distance of top of the line. This is for gaming, photoediting, perhaps video editing, perhaps watching movies.
I've already bought some components. They are:
Antec P180 case
Logitech wireless keyboard/mouse
2x WD Caviar 500GB SATA II hdd (WD5000KS), will set up in Raid 1 config
Samsung Dual layer DVD-RW, SATA (SH-S183L/BBEN)
2x 1GB Patriot Extreme DDR2-800 (PDC22G6400LLK)
What that leaves to buy is the Mobo, the cpu, the vid card, and PSU.
cpu: waiting on 4/22 price cut, most likely get a e6600 or e6700. Can upgrade to the faster intel cpus that use 1333 MHz FSB late this year, early next.
mobo: I'm thinking of a nVidia chipset because it will be able to run 1333MHz FSB cpu's, which the current intel mobo's can't. So probably a 680i, 650i flavor? That way, I can keep whatever mobo I buy for at least one year before I have to upgrade it, maybe 2 years, and if I can OC to stay within shouting distance of top of the line, so much the better.
video: I'm thinking 8800 GTX, but dang they are expensive. If necessary, I can SLI them later when the 8800 GTX prices get low. If not SLI, then perhaps buy the rumored 8950XT2 (SLI on one card) a year from now or so when prices get reasonable.
PSU: Taking into account possible SLI, future vid card power, and capicator degradation after a years worth of use, I figure I need a minimum 850W PSU. However, if I SLI two 8800 GTXs, then I need a PSU with 4x 6pin pci-e connectors. And future vid cards are rumored to require 1x 6pin connector and 1x 8pin connect, so by having 4x 6pin pci-e connectors I should be able to get 1x 6pin and 1x 8pin out of them, shouldn't I?
I know eventually the mobo is going to have to be replaced because of PCI-3, or DDR4 memory, or what have you, but right now, there is nothing that supports those future standards. So where are the flaws in this strategy?
P.S. not looking for recommendations on what particular component to buy, but if you want to suggest something, I'm all ears. I'm more interested in the logic behind purchases though.
I think you're thinking a little too far ahead with PCI-3 and DDR4. The high-end Intel motherboards coming out soon are going to support PCI-e 2.0 and DDR3 memory.
Take a look at this thread on jonnyGURU's forum, it tells you a little bit about 8-pin PCI-e connectors. I think it should be possible to use an adaptor to convert 2 x 6-pin into 1 x 8-pin, at least that's my understanding from reading some of that thread.
I wouldn't worry to much about getting sli, get one card and just upgrade it when you need to. I was looking to upgrade to a 8000gts and i may only cost me 50-100 bucks depending on how much i can cell my 7900gt for. You may have to upgrade more friquently with a single card but you will aways be near the best thing that is out. i dont think its worth trying to find a motherboard that will support ddr3 or pci3 2. I don't see anything coming out until summer for that kind of stuff. If you can wait i would try and get one of intels new cpus that are coming out... if you can wait.
Doh! My bad. I meant what you said.
I read that thread, that's why I think I need a PSU with 4x 6-pin connectors because I'll need 2x 6-pin to convert to 1x 8-pin, then I'll need one of the other 6-pin connectors just to power the next gen video card since the next gen video cards are rumored to require 1x 8-pin AND 1x 6-pin connector.
Not worried too much about it, but since I think an nVidia mobo is the way to go as of TODAY, then I'll at least have that option (unless I get a 650i that is). I like the flexibility though, and that's kinda what "future proofing" is all about.
No such thing as future proof in the computer industry.
But there is waiting. Wait for K8L, new quad core prices, and R600. Fair enough? They are coming in the next month or 2.
Seems like you are trying to future proof to much. I dont know if i would worry to much about the power requirement since most of what has been said is assuming that there wont be some kind of power saving in the future. both ati and nvidia are doing die shrinks so that will save some power. I agree you should look into the pcie 2 and ddr3 because those should be out within the next 6 months Getting a huge power supply may be a little to much. you will be wasting a lot of power for something you don't need just yet and may never need.
also i got an sli board too but dont think i will ever do it now...
It'd be better just to get a PSU with native 8-pin connectors because, if not, and you want to utilise Crossfire of SLi sometime in the future you'll need 6 x 6-pin PCI-e connectors!
Silverstone Olympia 1kw has enough power for pretty much anything you throw at it, and it has 8-pins too.
I don't understand this comment. Your computer will use whatever power it requests. It's not like if I have a 5 KW PSU that I'm going to use 5 KW even when idling at 150 W. Wasting power is measured by efficiency, not by the rated Watts of a PSU.
I want this PSU so badly, but i can't justify the cost seeing as it's only going to be powering an E6600, 8800GTX (maybe 2) or ATI's R600, a couple of hard drives etc. Whatever PSU i get i want to be able to reuse it when i build a second rig, or upgrade my first, which is why i'm thinking a Silverstone Zues 850w won't be enough. But i also don't want to get the Silverstone OP1000 and find that parts of it are obsolete when i come to build a second rig and have to buy a new PSU anyway. If i get the Olypmia, will i still be able to use it for years to come or will the Zues or Etasis 850w be just fine?
