Fusion machine on a PC?
Sayth
Can anyone tell me if there is any way to get a VmWare virtual machine that I created in Fusion on a Mac to work under VmWare workstation on a windows PC?
Do I have to convert the virtual machine somehow?
Thanks
Should work pretty much as-is, IIRC. If not, run it through vmware converter.
From VM Workstation 6.5 Manual
Using an Older-Version Virtual Machine Without
Upgrading
You might not want to upgrade a virtual machine because you want it to remain
compatible with other VMware products you are using. Following is a brief summary
of VMware product version compatibility.
Version of Workstation Compatible VMware Products
4.x GSX Server 3.x, VMware Server 1.x and 2.0, ESX Server 2.x and 3.x,
VMware Fusion 1.1 and 2.0, and ACE 1.x, 2.0, and 2.5
5.x VMware Server 1.x and 2.0, VMware Fusion 1.1 and 2.0,
ESX Server 3.x, VMware ACE 2.0 and 2.5, and VMware Player 1.x,
2.0, and 2.5
6.0.x VMware Server 2.0, VMware Fusion 1.1 and 2.0, VMware ACE 2.0
and 2.5, and VMware Player 2.0 and 2.5
6.5 VMware Player 2.5, VMware ACE 2.5, VMware Server 2.0, and
Fusion 2.0
You can run older versions of virtual machines in Workstation 6.5, but you will not have
the benefits of the new features of Workstation 6.5.
Also:
The VMware Conversion wizard in Workstation allows you to import the following
types of physical and virtual machines:
�� Physical machines
�� Windows 2000
�� Windows Server 2003 32‐bit and 64‐bit
�� Windows XP Professional 32‐bit and 64‐bit
�� Windows Vista 32‐bit and 64‐bit
�� VMware virtual machines (.vmx and .vmtn files)
�� Workstation 4.5, 5.x, 6.0.x, and 6.5
�� VMware ACE 1.x, 2.0.x, and 2.5
�� VMware Fusion 1.x and 2.0.x
�� VMware Player 1.x and 2.x
�� ESX Server 3.x
�� ESX Server 2.5.x (if the virtual machine is managed with VirtualCenter 2.x)
�� VMware Server 1.x and 2.0 x (if the virtual machine is on the local file system)
�� VirtualCenter 2.x
Workstation User’s Manual
134
Thanks guys.
I'll have to compare the pros and cons of converting later so I now know to keep a fusion copy in case I decide to go back to the Mac to host the VM.
For now though I was able to get the Windows VM to work on Workstation by deleting the LCK files.
As for the Ubuntu VM I was trying to migrate, I had to use the converter. Nothing I tried would make it work, but the conversion was quick and worked perfectly.
Mind you these are very basic VMs and consist of OS and one apache server. I don't know how well this would work from someone virtualizing a windows server or anything heavy like that.
As a side note, I used the converter locally on a live windows machine to make it into a VM and it worked flawlessly. In case anyone was wondering.
Thanks again!
