Hmmm, if you RAID 0 a pair of 128GB Samsung 840 Pro SSDs, you can meet or exceed those specs in everything except 4KQD1 reads.
In real World usage (the 4K reads), a Fusion IO will blow 840 Pro out of the water.
That's hilarious!![]()
Hmmm, if you RAID 0 a pair of 128GB Samsung 840 Pro SSDs, you can approximately meet those specs in everything except 4KQD1 reads:
http://www.rwlabs.com/article.php?cat=&id=762&pagenumber=8
Great scaling due to write caching and well more than double the score of a single drive. 4K reads are class leading and access times are correct.
I don't think those 4k qd1 write numbers are correct.
I don't think those 4k qd1 write numbers are correct, at least not if that's what http://www.guru3d.com/articles_pages/samsung_840_pro_ssd_benchmark_review_test,14.html reports. 4k1 can't scale across raid, so it wouldn't matter that it was raided.
I think http://www.hardocp.com/article/2012/12/10/samsung_840_pro_ssd_review/9 is about as accurate as we can get for 4k1, which is still damn good.
It is probably due to write caching. But as you say, even a single 840 Pro will approximately match the 4KQD1 write numbers of the FusionIO in your OP.
So, the fusionIO 4KQD1 read speed is impressive, but a pair of 840 Pros is mostly equivalent in the other specifications. Which is what I wrote in my previous post.
What's your point?
Apparently beyond your ken.
So this is an another way of saying "I'm so over you LOL".
It is a way of saying that the answer to the question has been stated twice in this thread already, and yet you have somehow missed it.
You're hilarious!![]()
In real World usage (the 4K reads), a Fusion IO will blow 840 Pro out of the water. The controller is much, much, much superior. So is the flash and the quality of the flash used. So is the BBU on the Fusion IO. It's faster, and much more, much more reliable. There's no comparison. It's a top of the line enterprise drive made to replace a giant rack full of 100-200 HDD's in IOPS. It puts out much more IOPS than the Samsung drive. The 840 Pro, on the other hand, is no more than your off the shelf high end SSD.
And you also have to keep in mind that that RWLabs (man how do I hate shitty little review sites) bench is done on an empty, zeroed up, boosted up drive. It screams BIAS all over.
why do you care about random 4kb reads so much?
I'd love me one of them for mysql![]()
840 pro is the newest and best ssd, and that fusion io card is old. And it still does 4k read 2x faster
There's only a single cell AND a SINGLE STATE on the Fusion IO. Convertional SLC SSD's are single cell, DOUBLE STATE. MLC is, dual cell, QUADRUPLE state.
Nonsense. I'm not sure if you make this stuff up for fun, or if you are just unable to understand how flash memory works.
SLC flash stores a single bit per cell, and a bit has two states (0 or 1). MLC flash stores two bits per cell, and therefore has four possible states: 00, 01, 10, 11. TLC flash stores three bits per cell, and has eight possible states.
As for the rest of your post, you repeated everything I said...
You're hilarious. What you wrote is utter nonsense.
A single-state storage cell? Yeah, it is really useful to store nothing but zeros. You could just sell an empty box as a single-state storage cell. Want to buy a box of a trillion zeros? 1TB, only $1.
You could sell that along with some write-only memory (WOM).
I suggest you do do some research on "ZeusIOPS"
You're hilarious!
You have no clue what a ZeusIOPS is, and how it's writing algotirm is ENTIRELY different and how different of a drive it is than a convertional flash drive.
I got a RAID array of a pair of Deneva R2 SLC's, and they're "the" shit indeed. While I was testing single drive on ATTO, I've once seen 600 MB/s read...![]()
can you post as-ssd for them?
$200 for 100GB is a bit ludacris, however, if you're looking for a server/datacenter SSD, then this is what you should be looking for.
Another enterprise SLC SSD for comparison. It was being slightly used at the time I ran the benchmark, but I couldn't be bothered to close Steam.
I'd hold out for the Intel PCIe ones. You also want to avoid OCZ like the plague.
