Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
thank you. I guess, my confusion was, i see people all the time comparing stats, or asking for temps, or showing screens..... but things are vastly different, depending what you turn on. Turn on postFX, and your temps will SHOOT up. Also with MSAAA.
So i was confused, if there wasnt a standard, how can you possibly compare, or get an accurate reading? Turning on FX, will severely change your stats.
But looking right on their front page, they list what the standard is.
Yes that is their standards. Most of the time when they compare and or change a setting they will tell them that is what they used. I turn mine up on max everything. If your going to crash, you might as well go out maxed out.
But honestly 60 seconds isn't going to do much unless you just went super sky high on the clocks it will or may crash that fast. I do 5 minutes or so. As the average benchmarks are that and even longer. As vantage is about 15 minutes i thing to do it.
