Funny molex remover
BLG
Well i was sitting around thinking about buying a molex remover because i didnt want to sit with a paper clip in hand trying to pick those little pricks at the sides of the pin, but then it came to me...make your own molex remover..which is exactly what i did, its a male molex remover made out of paper clips and electrical tape, took me a little while to get the circle the perfect size to take the pin out everytime but i finally got it...
I just find it really funny :p lol <3 4 paper clips... my new goal the female molex remover out of paper clips this will be a challenge but im up to it. :D
edit: this was suppose to be in the modding section my bad too much excitement
I'll try to get a good shot but since its so small its hard to get a clear picture
edit: Here's one its really bad sorry! :(
Tell me what you think!!!!
So what do you guys think? come on give me some feedback, only problem is its a just a wee bit flimsy so im worried that if i use it to many times it will expand teh circle, easily fixed, or break...not good but im happy with my own creation
When resleving my PSU I was the noob that forgot how much of pain in the ass the molex removal procedure was, and thus forgot to buy one of those newfangled Molex removers. So I had to make my own.
Mine was a Female Molex from another older compter. Stabbed one end into a eraser on a pencil and the other end I streched out with the ink tube from a BIC pen. Worked like a charm to get the Males out. All I had to do was, Insert-Twist-Pull.
I recommend mine to anyone who forgets to buy a remover. If you are cheap or forget then its really quite easy to make/use.
thats a good idea i was trying to figure out a way to make a female remover and it seemed more difficult but i think that will work relaly well for me
