Progress so far. Will have to clean up the wiring when I'm finished. The blue Radeon card will take some getting used to.
when youre on the home page of crimson control there should be a button in the bottom left.
Now having an issue where both cards are installed and not even going to post...
But yet when I uninstall one card the machine works perfectly. Both cards work perfectly separate as well
Get that dust scrubbed off!
Does that Arctic 120 cool Threadripper sufficiently??
What PSU are you using. If that's good maybe a bios update for the motherboard. So jealous, that's a beastly setup.
So now that I have Crossfire working and can see both cards it seems as though the machine "lags" for example when I move the mouse in a circle on the screen, the pointer on the screen seems to have a 1/2 second delay then it speeds back up to normal. Gremlins...
Weird. If you disable crossfire does the lagginess go away?
disable ULPS see if that helps.
So I rebooted the system with both crossfire off and on. Still lagging with the mouse. I also disabled upls as well...no go. I think I am going to try a driver reinstall for everything.
well so far so good then.UPDATE: So I completely reinstalled Windows 10 Enterprise and the mouse hitching went away, crossfire is working perfectly. I won't have much of a chance to run anything this week because I am at the each for a weeks woreth of vacation before Teachers are due back to work next week before the start of the new school year. The first WHQL drivers for the VegaFE should be out sometime in September based off the 17.7.2 branch.
