Fully Automated
Sunin
[H]ard|DCer of the Month - August 2008
Well I just finished fully automating a F@H machine.
It now does the following automatically:
1. Login
2. Sets the graphics overclock and fan speed
3. waits 30 seconds loads gpu client
4. waits 15 seconds loads F@H1 at idle priority and minimized
5. waits 15 seconds loads F@H2 at idle priority and minimized
WAlla... instant folding...
I'll try to get some pictures etc together. Shortly. I used a tool to do the delays and setup, I used rivatuner to set teh overclock and fan speed and used
start and run then typed in
control userpasswords2 to setup the auto login.
I'll get together something with more details in the next couple of days.
Nice man, you should create some sort of script file, or Windows Automated install disk with nLite, with auto startup scripts, etc.
Good Luck!
could probably do it with powershell on vista... xp might be a little more painful (but doable) with wscript
Great, remain to find out how to automatically start VMWare and the VM instances and I'm set :)
