mooseontheloose
- Feb 3, 2009
After putting together my new build recently, I decided I'd really like to move to a full tower and I'm currently trying to decide on which to go with.
I looked at the Antec 1200 and for some reason, it just doesn't appeal to me. If I did buy it, I would spend some money to get a custom window because I hate that side panel.
More so, I've looked at CM products such as the HAF, Cosmos S, and Stacker.
I've really been leaning towards the Cosmos S overall, but I'd like input given my plans for the future.
1. I will paint the interior (black) of any case I buy, so the 1200's interior is a moot point for me.
2. I will be installing water cooling sometime in the spring or summer, so my concerns for cooling mostly reflect a water set-up. I understand the 1200 and others are great for air, but I'm not too concerned about that since I'll only be on air for a few months.
3. I will do some extensive cable management, and whichever case I get needs to have decent options for this. I am not against cutting some holes to make cable routing easier (as I would do on the Cosmos), but I'm primarily concerned here with the basic layout and ability to run cables behind the motherboard (non-modular PSU).
Overall, I'm drawn to the Cosmos for its water cooling options and general look/design. I've done less research on the Stacker overall (though the look is nice), and the HAF seems like a great option but I just can't stand the side panel. Overall, each case (including the 1200) isn't perfect to me, which is fine, but I'm not sure how to make the decision.
Thus, opinions from people who've used one or more would be great. Water cooling users = even better (I want to do it all internally).
