I have a few laptops that are having random BSODs. I think I've figured out the causes (various issues with BIOS, wireless drivers etc.) and addressed them, but I'd like to do some stress testing of all the various I/O subsystems to see if I can provoke a fault.
While some CPU load would be nice, I'm not looking for OCCT but something with a stronger system perspective. I'd like to stress the local disk with some random I/O. I want to pull data off wifi near the limits of bandwidth. I want some GPU load going on. I definitely want some heavy system RAM stress. I want to run these tests with my antivirus, drive encryption, etc. software running so I can build up some confidence that the issues are in the past.
Any suggestion on a tool that I can use that does multi-device, I/O-oriented stress testing?
(If not, my plan is to have a cmdlet to batch copy thousands of small files back and forth between local storage and remote fileshare over wifi, while running some disk stress test, while having a curl script grab a random set of websites every ten seconds, while hopefully running some GPU test that runs in windowed mode.
