Fujitsu XL3220T - US compatible?
Shoyz
https://sp.ts.fujitsu.com/dmsp/docs/ds-display-xl3220t.pdf
I've become smitten with this monitor due to it's LED and white frame, but being a UK exclusive I was wondering if importing it would work?
"Rated voltage range 100 - 240 V" should mean that it's power compatible and I'd just need a separate plug or a UK to US adapter, but I'm not sure about it's compatibility with my US computer or US PS3. If anybody could help, thanks!
Monitors are not limited to a specific country, as they don't need to comply to NTSC/PAL/etc like old TVs. In this case you just need the plug adapter. Good luck!
