erdeminoff
- Mar 30, 2015
Posts From Another Forum:
First Monitor Technical Details :
03.26.2015
Hi. I bought a old L22T-2 monitor today and wanted to run this monitor 1920x180p 75 hz. But its seems only 60 hz from display properties. (Amd catalyst shows 75 hz to supported refrash rates but its not working) Also I dowloaded cru and patched clock limit my Amd R9 270x driver. In the beginning I used default 60 hz values from cru and set 1920x1080 70 hz. After restart Its seems 70 hz from display propertious but this time image not scaling correctly. So I think It should be from resolution parameters. SO I need correct parametres from best scaling. Here: Tecnical Details of L22t-2
Please help. Thank you
03.30.2015
Finally I sucess to run 1080p 70 hz. I found three different timing parameter with correct image scaling. Sharing for others :
Other Combinations:
Edit: Same parameters are working on 72 hz without problem
But i didnt pass blur problem. When increase refrash rate screen is bluring. I got max sharpness from 1080p 40hz. SO need a solution. I think maybe it ll resolve from vga connection. I want to try that :
What do you think? Is this metod increase sharpness?
03.26.2015
03.30.2015
Other Combinations:
