Fujipoly...your VRM's deserve it
psyclist
Hey guys,
Just thought id report my findings switching my stock thermal pad for my VRM's to Fujipoly Extreme.
Before VRM temps were about 10 degrees higher than whatever the core was reading when fully loaded so at 80 core the VRM's would hover around 90
After the quick fix VRM's are now 5 degrees below the core! So just by switching the thermal strip ive saved 15 Degrees! Just wanted to report in for those thinking about it or having troubles with the VRM temps, reference cards dont have an issue in this department but many non ref solutions keep the core cool but VRM's get hot when pushed.
These temps all come from the same clocks of 1175/1500 and +100Mv on my Gigabyte Windforce 290X at 25 Degrees Ambient.
FrozenCPU has all the flavors, Dont bother with the Ultra Extreme, it will work better...But to me, not worth the premium over the Extreme
What are your temps so overall? Idle core and VRM temps (include ambient). I bought some Fujipoly extreme a while back for my 7950 and Arctic Accelero but I decided to keep them until my next upgrade, which could be a Trix 290 :p
Been using fujipoly thermal pads with good results for about 2 years. Great thermal pad.
Okay so I am defiantly interested what thickness would you guys suggest the .5, 1, or 1.5 mm stuff?
It depends on your card (and waterblock if using one) so you'll have to research that.
For my 780ti it needed 1.5mm pads. After using these pads (I think extreme, the 17W stuff) my VRM's are around the same temps as my core, which is 52C max or so.
What sizes did you use on your WindForce? I have heard that GIGABYTE uses 0.5mm on the RAM and 1.0mm on the VRMs. Is that accurate?
I bought a sheet of the 0.5mm Extreme, I just doubled it for the VRM's. Worked Great!
What size would I need for the ram/vrm on a EVGA 780 gtx with ACX cooler?
Edit: Most likely .5mm and could do everything with a 60x50mm piece (~$6 at forzencpu) if careful with cuts.
