The only problem I would see, is if the total amps pulled by all the fans gets too high, the wire might burn up...but most fans don't pull alot of amps. Unless we're talking about 6 monster cfm, 120x38 fans
burn up?!?! ._. hm then should i put 3 of them on a different molex? i have a tornado, 3 120x25, 1 120x38, and a 92mm.. the tornados only at half its rpm tho
the reason why im wondering is cuz on the rpm reader when i up the speed on the tornado the readings start acting wierd.. like when i press the + button itll look like 2500rpm -> 8000rpm -> 2600rpm -> 8000rpm -> 2700rpm.. so i was wondering if this is cuz the powers unstable
