Fubar'ed my Ti4400... Soldering help?
MChief
Hey all.. here's the story...
My trusty Ti4400 was locking up in games after years of faithful service, so I pull it out and sure enough the fan is locked up. After a few months of successfully playing games with a large box fan blowing directly inside my case, I got fed up with it and decided to replace the heat sink with an aftermarket fan.
It was a huge pain in the ass, but once I got everything back together and installed in my system, I had artifacts during POST, and windows locked up going into SVGA mode. I can run XP in "VGA" mode (640x480) but there are massive artifacts.
So I remove the card and heatsink to see what I fubared. Apparently during removal of the old heat sink or installation of the new one, I ripped a capacitor off of the PCB. Its right below the GPU on the second row, labeled C1358. This card is an Nvidia reference PNY.
I pulled a similar-looking capacitor off of an old PCI card I've kept around for spare parts, removed what was left of the old capacitor and tried to solder the new one in place of old C1358. I don't think I'm quite making contact with these surface mount points, because the artifacts are staying. No matter what I do I can't seem to make contact or get the solder into place. Maybe I'm using the wrong size capacitor. I figured something close would be better than nothing at all :).
If anyone has experience with surface mount capacitors, I'd really appreciate some input! As it stands I'm going to have a friend that works with this stuff try and get the capacitor (or another one like it) mounted.
I can post some pictures of the fiasco, but some of the buttons on my Samsung Digimax 210se quit working - maybe that will be my next soldering project :).
Thanks
-MC
I have the exact same problem with my Ti4200. I knocked a capacitor off and I don't know what to do. I don't even know what the value is to buy a replacement or how to even being soldering it back on because the area to work in is so small. There was also a insulating washer underneath it as well.
Spair-
Its a pain in the ass to work in there, I won't lie, but its actually easier than you might expect. Since the area and solder amount is so small, it heats and melts quite quickly. The problem I've had is getting the solder to go where I want it to.
The card is quite tough, for the most part, and as long as you don't zap it with static electricity I don't think you have to worry about heat too much.
It looks to me like you pulled a coil off, not a capacitor. In any case, if you can't work in that area you should be able to solder some small wires to the solder points, then solder those wires to the piece that broke off, and secure it to the pcb somehow (or just let it dangle and be careful)
I literally pulled a replacement part off of another card I had laying around. You could probably do the same. Your part either looks like a coil or a large capacitor, so I would look to old motherboards, possibly old stereo or any electronic equipment. I think in your case the part can be salvaged. Mine was literally gouged in half :).
I ripped off your picture and circled in yellow the kind of part that I ripped off. (Yes, its there, look carefully) :) My part was under the original heatsink and the bottom of the card.
Good luck...
-MC
I had the same thing happen to my ti4200. I didnt knock anything off, and everything installed fine, but then i got white lines accross the screen in post, and now it wont boot up at all. I tryed using Alcohol to clean everything, but that didnt work. If anyone thinks they can fix it i will let it go very cheap.
I did nearly the same thing on my FX 5900 but I did it twice lol. I got one back on, the other one was about 1/4th the size of a grain of rice and it went flying, i just closed the joint using some conductive paint and the card is fine now, though I will likely send it in and have it professionally repaired at PNY now that I got my GT installed.
You might be able to get away with just closing the joint. Probably would be the easiest thing to do.
However if you want to solder a new one back on, surface mount stuff isn't too hard if you have the right tools to help you out. First you need a soldering iron with a really fine tip. Second a tweezers so you can hold that tiny cap, thrid some really fine (hairthick) solder, and fourth some type of soldering removal tool.
Try to remove as much solder off of at least ONE of the pads that the caps rests on. Once you do that, heat up the solder on the other pad, and place the cap in place, use that existing solder to hold the cap in place while you get it positioned. Once positioned remove your soldering iron. But be careful, don't let the iron sit to long, don't want to burn the PCB. Once the cap is in place, solder the other side. Then apply more solder to the first joint if it is needed. Thats all you need to do, but its easier said then done. Good Luck!
Thanks Sniper and Paully. I'll give it a shot and post my results tonight.
