i'm having a problem transfering files using ftp through the windows command prompt. I can easily send individual files, but when i try to send a folder full of stuff i get an error:
Error opening local file
i'm using the put command, instead of using put, is there another command to send a directory?
EDIT: should "put dir F:\JBi" work?
EDIT2: should i even bother learning/using command prompt or should i go out and dl a different ftp client?
