I'm trying to decide between these three cases.
I'd like to use an i5-2500k and a MSI Twin Frozr III PE/OC GTX 570 video card.
I'm having trouble figuring out which case with which setup would be the coolest running option. I just don't want to get too ungainly a CPU cooler in case I have to move the machine around a bit. I would be down for using a Corsair H50 or H60 or something like that but I haven't heard good things about them. Is the H60 significantly better than the H50?
Anyway, cooling and longevity are my only concerns. I do play games frequently. I don't care about noise issues at all and I'm perfectly willing to run all fans at 100% 24-7.
Which would you guys suggest? I'm looking for a case and cpu cooler suggestion.
I don't have any plans to overclock the CPU significantly just yet (doubt it'd have a huge impact in games), but I am considering a slight overclock and/or an undervolt right off the bat.
I would like to keep the CPU and GPU load temps in the 60s, maximum. I don't want it going into the 70s or beyond.
Other info:
One 3.5" HD, maybe an additional 2.5" HD if there's room but the second isn't necessary.
Other info:
