mrmylanman
- Jul 13, 2008
So I decided to purchase my FT01B-W case as well as the following:
Intel Core i7 920
Biostar TPowerX58
3GB Mushkin DDR3-1600 (gotta fix this part in the BIOS, the SPD is WAY off)
Silverstone ST70F (700W modular power supply)
640GB Western Digital hard drive
LG DVD-RW
ATI X800 Pro (very outdated, I know. I'll fix that when money becomes available. I had it around he house)
Something is shorting out. The problem is I don't know what. When it is all installed in the case, it does not turn on. When I say doesn't turn on I mean nothing turns on. No lights, no errors, no fans.
When I take it out, and put it all on a table, it works just fine.
Short of electrical taping the entire motherboard tray (which is powder coated anyway so I am not so sure that is the problem, what can I fix? I mean, maybe the standoffs are hitting something (poor motherboard design perhaps?) but I don't have any with a rubber grommet on them.
Any more ideas?
Intel Core i7 920
Biostar TPowerX58
LG DVD-RW
Any more ideas?
