R-Type
[H]ard|DCer of the Month - October 2011
- Mar 6, 2006
I've got a pristine RTX 4090 with EKWB Vector2 WB installed for trade. I've only put a few days of actual usage on this since buying it 12 months ago, as a coil whine issue on the motherboard made me tear the system apart and then my son was born... you can follow the rest. While I still need a GPU and something to tie into my loop, this is just massively overkill for the time I'm able to allocate to gaming. Looking to trade with the block installed for a previous gen or lower tier current gen card that also has a waterblock, plus cash. We can use recent forum prices to come to an agreeable difference in value.
Let me know what you've got!
Heat under R-Type
Heat under R-Type
