RJ1892
- Apr 3, 2014
I'm looking to swap all my fans out in my FT-02, replacing the bottom 3 with the AP182's, also changing the fans on my NH-D14 to 2 NF-A15's. Anyways I was wondering if anyone knows if the NF-P14 that came with the NH-D14 will fit in the exhaust area of the case. I know I could tear everything apart right now and take a look, which I may have to do. But I was wondering if anyone knows off hand. It would just need 4mm of clearance on each side, I believe to fit.
If not I'll probably buy another 120mm fan for exhaust.
Anyways I decided to swap out all my fans mainly because yesterday I re-pasted my GPU and noticed that 2 of the AP181's it came with were dieing. Any opinions on this fan update? I'm just trying to maintain a quiet build with decent air flow.
