fsuntil.exe missing?
shawnoen
Just secure erased my SSD, installed fresh WIndows 7 Ultimate (and Intel RAID drivers during install). Everything went fine, no errors.
Booted to desktop, installed normal Windows updates. Also installed Intel SSD Toolbox and everything seems fine.
Just tried checking via command prompt if TRIM was working and it says "fsuntil is not recognized as an internal or external command, operable program or batch file".
WTF? Whats going on here?
Checking google nothing on fsuntil... fsutil yes ....
http://forums.techguy.org/windows-xp/540091-disable-chkdsk.html
recommands to type in a command line to type chkntfs /x s: then reboot
tho no mention of ssd
this one s close to what u have and even mention trim
http://www.techsupportforum.com/for...pc-keeps-freezing-during-gameplay-589021.html
says :"Have you been running the TRIM command regularly on the SSD? if you do not do so it will cause your SSD to function improperly and eventually degrade into nothing.
Click on Start > Type "CMD.exe" in Search box > Right click on "CMD" and select "Run as Administrator"
In the Elevated command Prompt windows, type the following: fsutil behavior set disabledeletenotify 0
You could try that tho the guy ended up with a bad stick of ram.
Ya, no hardware issues at all. Was just going a reformat because of a stupid virus. What a PITA.
