Fsb????
DREW10
hey
just emailed this to gigabyte support........
Hi,
I just purchased a GA-7N400-L for a new computer, the
FSB
specs. were 266, 300, 366, 400. I installed the
motherboard and in the BIOS the only choices I had for
FSB were 100, 133, 166, 200. So, I figured, maybe if I
install the software I will be able to change it in
easytune 4, I tryed it and I still cant change the FSB
or the multiplyer. I tryed changing the multipler on
the motherboard also and it still wont change. I have
an Athlon 2400+, and its only recognizing an 1800+ and
running at 1489 Mgh. How do I change the FSB and the
multiplyer????
Anybody got any ideas
THANX
DREW
You don't change the multiplier, it's built in (allthough some boards will allow it to be unlocked). Those spec FSB are DDR, 133=266DDR 166=333DDR, etc. You should set the FSB to 133 and it will run at spec.
