FSB Termination Voltage and OCing
9mmx19
What the hell does it do? I read on some Anandtech thread that raising it helped someone with RAM errors. Should I leave it on "Auto"? If not whats a safe voltage? Thanks in advance.
Arcygenical
This is basically the end of the BUS voltage... as the name Implies.
I believe the intel spec says that this can be up to 1.295v IIRC. It has an effect on stability too... IIRC. (it's been awhile)
9mmx19
Anyone know what the default or auto setting is? Is it something I should bother changing?
