fsb ratio
Glyphic
Just a quick question, should I try to run 1:1 or is 3:2 good enough? thanks (also this was the first system I built, but I wish I would have known to get faster ram :( )
also, for some reason I'm getting alot of program errors ( you know the ones where the error reporting thing pops up) any ideas?
you should at least try 5:4 on the ram. 1:1 may be possible if you bump the voltages and loosen the timings.
what is you CPU voltage? that may be able to solve the application error problem you're getting.
Not sure what to do for ram, I haven't gotten that far, the option in my bios are
dram cas - 3
ras precharge - 4
ras to cas delay - 4
dram precharge delay - ?
dram burst length - ?
ok, I have my ram running at 3-3-3 at 222, my bios doesn't have any settings for fsb to ram ratio, is there another way to do this?
