FSB question. Mobo has higher FSB than CPU
I wanted to make sure, before I took anything out of the box... That I'm not gonna fry my processor before I even use it.
Here's the CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116070
Here's the mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128338
The mobo has a 1066/1333 FSB
The CPU requires an 800 FSB
The only thing I checked when I ordered the parts was to make sure they were both using LGA 775 architecture.
Could this difference on the Front Side Bus cause me any issues?
Do I need to replace either the mobo or the processor?
Problem solved. Checked the gigabyte website for supported processors. The processor I have is listed.
A general rule of thumb is that a motherboard will be able to support most, if not all CPUs that use lower FSBs than it supports. They can always go down, but not always up. Of course, it also depends on the specific model of the CPU and whether or not the motherboard supports that range of CPUs, but you can usually get a pretty good idea of what CPUs a board will support based on the chipset it uses.
X48 is the only chipset from Intel that can't support 800MHz FSB
That is incorrect. The X48 chipset supports all 800MHz FSB Core 2 CPUs. I'm not completely sure about P4 and Pentium D support, but it definitely works fine with C2Ds and C2Qs.
