I have an old Luckytech P694A mobo and I want to use it to build a system. I have the disk and manual that came with it. I also have several questions and I would appreciate specific answers to my questions as well as general advice. The idea is to build a system with parts I already have or which I could get for little or no cost.
1- The manual says it supports (1) SDRAM as well as PC100/133 and (2) DRAM ECC or parity. I am assuming I will have to match the speed of the memory to the speed of the FSB. Right?
2- It says it supports Intel PII, PIII and Celeron but it does not especifically say up to what speeds. I am assuming the max speed is given by the FSB speed times the multiplier ratio. Right?
3- FSB. This is what has me most confused. The manual shows three options which can be selected with jumpers. The options are
(1) Auto detect,
(2) 66 overclock 100 and
(3) 100 overclock 133.
I have no idea how to interpret this. I am assuming (1) means the board detects the FSB speed from the processor but what do 2 and 3 mean? I think there may be an option to set the FSB speed in the BIOS. I need to understand the issues raised by the three previous questions as they are all lnked and I am confused.
4- The multiplier can be selected between 2 and 8 so, if I have the FSB at 133 this means I can have the processor running up to 1000 Mhz. Right?
5- The AGP slot is 4X and I have an AGP board which is 2X. I assume I can use this board and the mobo AGP will sloww down to 2X. Correct?
I have pretty much everything I need except processor and RAM. This means I will be looking for cheap / free processor and RAM. Supposing I can choose, what would be the best choice?
Thanks.
(1) Auto detect,
Thanks.
