FSB Help!
kc690
Ok here is the problem when I oc the highest I can get is 360 fsb.
Bios settings are cpu ram fsb linked, 1:1.
When I try 365 it goes into its safe mode and ask me to change settings, when i try to change vcore it doesnt seem to help.
Then if i try 370 at stock vcore 1.275 it doesnt go into safe mode but vista doesnt boot.
So what are my options now or what can I do to get it to work, also it seems like anytime i try and change vcore it goes into safe mode.
You've tried increasing the CPU voltage... right? Northbridge voltage increase can also help.
Ok I changed it from 1:1 to sync mode and it made it into vista once at 365 but it froze when I tried running 3dmark, and now when I restart it, it goes into safe mode again with the same settings.
Well the only voltage I can increase is the cpu voltage and everytime i try and change it nomatter what the fsb is it seems to go into safe mode.
It looks a lot like the motherboard's fault. nForce 610i? Lol doesn't sound like a good northbridge.
If you want to OC, get a good P35 board.
