FSB Comatability question... better safe than sorry
DudeItsMe
Sorry if this seems like a bit of a dumb question. I think I already know the answer, but would be nice to find out otherwise :D
I am looking to build a relatively inexpensive computer for a business envrionment. I'm not really budget limited, but I would to build something with some decent performance that will have some upgrade capabilities.
I'm finding that upgrade options are limited by the FSB speed of the board. If I get an Allendale C2D, I have to get a board with an 800 Mhz FSB, which would let me upgrade to a 1066 Mhz FSB (some Conroe cores) in the future. However it seems like I could get a better motherboard if I was using one that was 1066 Mhz FSB/1333 Mhz compatible.
So basically I have two questions:
1) Would it be possible to run an 800 Mhz FSB proc on a 1066/1333 board? (this is the dumb question)
2) Do you think that a 800/1066 motherboard will provide viable upgrade options in the future (as in, will there still be a large number of 1066 processors out there, or are they moving up to 1333 processors?)
Thanks in advance for the help :)
Ehhh nevermind... I managed to justify the jump to a Conroe chip, so this isn't really an issue anymore. Cost is going to go up a bit, but we're going to shuffle out an older system and replace it.
