FS-X sound problem
srxshadow
Flight Simulator X
Has anyone experienced/know how to fix : sound problem that happens when playing and cycling views? it is loud static noise, and if I toggle the sound(Q) off and on the normal audio resumes. It has also happened a few times while changing flap/gear settings. The game otherwise plays perfectly.
I have tried updating my sound drivers etc. and doubt it can relate to corrupt files since it won't happen unless you change the aircraft view.
