Please PM me if you have any questions or offers. If you check the thread please bump
Local pickup is available in the Louisville, KY area.
Shipping will be UPS ground or USPS priority and will be professionally packed by my mail room and insured for the value of the equipment. My packaging has always been top notch as you can see in my heat.
Wanted
gen1 surface pro for cheap
60-120gb msata drive
asua q87t
sodimm ddr3 8gb 2x4 ram
Sold:
19 Black EK Fittings +1 Silver ek fitting
Tubing
BP 90
2x BP 45
BP Extenders
Contact Info:
#1 - PM on Hardforum's
Aim: Kenjiwing
Murdermod Mid Plate 2 holes $40
Two holes cut in it for bitspower passthrough fittings. Holes are 20mm and are perfect for going from bottom compartment to the top. Powder coated flat black.
Murdermod Acrylic Top Glass with crack $20
This is from Charles purchased years ago.. I stepped on it while taking my pc apart and put a small crack on the side as you can see in the pic. This is impossible to notice
once it is together but I wanted to disclose it
Lamptron FC4 $15 shipped
Used but still works perfectly. All channels run. Light up blue if thats your thing.
http://www.xtremesystems.org/forums/showthread.php?234066-Lamptron-FC4-Fan-Controller-Review
Phobya G1/4 Inline Female to Female Temp Sensor Coupler - 2-Pin - Black (71225) $9
http://www.frozencpu.com/products/2...Pin_-_Black_71225.html?id=UgJkWpp7&mv_pc=1567
Sealed brand new. Works awesome
EK 90/45 Fittings $7 a piece $13 for both
Bought these brand new and did not use them because they didnt match my BP sets.. yes im that anal lol.
Bitspower Fittings 90/45/Caps/Elbows/C47s
Fittings are used but in good shape unless noted otherwise. Most of these were used in my old build and could use some cleaning and have minor scratches.
2 BP 45 degree rotary $7
http://www.frozencpu.com/products/1...te_Black_BP-MB45R.html?id=UgJkWpp7&mv_pc=2571
2 BP low profile caps $2
2 bp chrome large caps $2
2 BP c47s black - new $8
unused brand new
1 Bitspower Anti Twist Rotary Extender $7 - unused
http://www.frozencpu.com/products/1...e_Black_BP-MBDR-C.html?id=UgJkWpp7&mv_pc=1877
1 Bitspower male to female extender 15mm $3 - unused
http://www.frozencpu.com/products/1...BP-MBWP-C60.html?id=UgJkWpp7&mv_pc=4083#blank
E22 Push Fitting chrome 12mm tubing $10 - unused
Used for testing nothing else. No water has run through it.
EK Res X3 250MM Tube with Bottom port. Missing top. $28
This is a weird one. So I bought two ek reses and ended up only using one.. then I ended up giving a friend one of my bottoms for one of his tops. Ultimately what that means is
I have a brand new EK Res X3 250MM tube with a top with a single hole and no bottom cap. This can be purchased for about $15 so if someone needs a res this is a great way to get one for cheap. I also have the orignal box with manual and the mounts so literally all you need is a single top of your choosing. A great deal for someone that needs to buy stuff already and can just grab a top for $15 making a $65 res $40.
Wanted
asua q87t
Sold:
Tubing
BP 90
2x BP 45
BP Extenders
