FS: Unlocked 6950 Direct CU II, Active DP and mini DP adapters, DDR3 1600 and more
R-Type
[H]ard|DCer of the Month - October 2011
3/21 - Price Drops across the board!
Clearing out some spare parts, everything is adult owned and in perfect condition unless otherwise noted. If you have any questions please shoot me a PM, I will however ignore lowballing.
I have heat under R-Type, ship via USPS to the contingent 48, and greatly prefer Amazon Payments.
Asus 6950 Direct CU II 2gb Unlocked - SOLD
3x Dell 2005FPW IPS displays with removed bezels on triple LCD Stand - $325 local pickup only (Seattle)
These Dell 2005FPW's have been trusty displays for years and still look great, with 12ms and low input lag they also perform admirably in games. All 3 monitors have had their bezels removed before being mounted to an adjustable 3-in-1 monitor stand (original bezels and stands included and can be easily reassembled if desired). The stand allows for use of the displays in either portrait or landscape orientation and I am including 10' DVI cables which route through the stand and provide the slack needed for adjustments while staying tidy. I love this setup but am moving in a couple of months and have downsize to a single large display for space purposes.
More details on the bezel removal can be found here: http://hardforum.com/showpost.php?p=1036939379&postcount=2
3x HIS mini-dp to DVI active adapters - 1 @ $18 shipped, 2 @ $35 shipped, 3 @ $50 shipped
http://www.amazon.com/gp/product/B004RFGK30/ref=oh_o04_s00_i00_details
These are brand new and unused but lack their original boxes (I bought them for the Radeon above not realizing it had full size DP.
3x HIS DP to DVI active adapters - 1 @ $20 shipped, 2 @ $38 shipped, 3 @ $55 shipped
http://www.amazon.com/gp/product/B00439G3NW/ref=oh_o06_s00_i00_details
Used for about 3 months with the Radeon above, work great. The sleeving on two of them developed a small crack from use but as a friend has had the same experience with these it seems to be just par for the course. This in no way affects functionality of the adapters.
4x4GB G.Skill DDR3 1600 Ripjaw X - $70 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231429
Work great, lifetime warranty.
2x4GB G.Skill DDR3 1600 Ripjaw - $35 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
FSP 270W Mini-ITX/1U Power Supply - $40 shipped
Replacement PSU for most Shuttle systems, only used for a few weeks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104073
Zalman MFC-1 Plus 6 channel fan controller - $30 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999171
The clear anodized version of the above fan controller (Note: NOT black). I have sleeved the wiring and the unit is in perfect condition.
CA10N sata BD-ROM/DVD-RW laptop drive - $35 shipped
Bought from another forum member, this lacks a faceplate so you will need to find a compatible one for your laptop.
Bump, 6950 sold, eyefinity setup added.
Yes the aluminum bezels are the only way to go.
Morning bump
FS/FT is flooded with 7970's bump. Pick up an eyefinity setup for less than the gpu you'll run it on! ;)
